To be part of the discussion, create an account by clicking the Sign-Up button. Once your account is confirmed, you are ready to post.
Before creating a new post, take a look at whether someone else has had the same issue in the past. The community members might already have resolved your problem!
config.php VS config_extended.php
The possibility of having to edit one of these two files above is quite high. Check what is the difference between these files on this detailed topic.
Topics marked as "Solved"
This means that the issue described on that topic has been resolved with the help of other community members. An example of a Solved topic is this one here.
Before posting, have a look at the phpList Code of Conduct!
