Hello guys,
I just followed the instructions to update phplist to 3.3.6 and got stuck with this message:
phpList is in maintenance mode.
Please try again in half an hour.
Found this old threat about it but is not working for me since I don’t have “maintenancemode” in my DB. Tried creating a new line for this, but the problem persists.
Previous version was working fine. Do you have any idea?
Thanks for the help
Never mind, I found the maintenancemode line, I was looking for in my backup database.
For the records leave the maintenancemode in blank solves the issue.
This happened to me after choosing the auto upgrade option. Normally I upgrade manually flawlessly, but I decided to use the new feature, and it seemed to hang. Now I get the “Stuck in Maintenance Mode” message and can’t seem to do anything.
Where did you find the maintenancemode line? I looked through the tables and could not find this field.
I have found that maintenancemode is not a field to be edited, but a line to be deleted in the config table.
Solved!
@sasciame Welcome yo the forum - happy to hear you fixed it. Thanks for letting us know!
