Hi, what file do i place the bootstrap overrides css code in.
For a example i want to do this
/* overrides */
.navbar-inverse{
background-color: #8796b4;
I did try it in the three css files in the /styles folder but i could not get it to work. Is there a particular file that this custom css override would go in to load? I am trying to change the header bar color for the subscription page (the bar with the logo).
Update: So i did find an article [SOLVED} How to edit default subscribe page so i guess i can just link a custom css in the settings area for the header and then it will load my custom css overrides. That should work i think…
Yep that worked, as long as you load the custom css AFTER bootstrap ui css then it will work fine.
