Segment Plugin does not work
I want to use the “Segment” (bramley / phplist-plugin-segment)
https://resources.phplist.com/plugin/segment
Segment” plugin (2.1.0+20150903)
/path-to-default/admin/plugins directory.
I put into the directory,
will become a “White Out” management console.
httpd, php, MySQL, etc., it is a situation that is nothing is output to the error log.
What kind of problems do will be considered?
Those who have been in the same situation?
・CentOS 6.7
・httpd 2.2.15-47
・php 5.3.3-46
・mysql 5.1.73-5
・phpList 3.0.12
・Segment 2.1.0+20150903
@junysb3 Have you followed the installation instructions https://github.com/bramley/phplist-plugin-segment , specifically the dependencies?
You will need to remove the plugin file SegmentPlugin.php manually to get phplist running again.
@duncanc THX for the help.
But,I have already done.
・Install through phplist
・Install manually Segment
・remove the Autoresponder Plugin
・UpGrade phpList https://github.com/phpList/phplist3/archive/master.zip
・DownGrade phpList 3.0.6
・disable PHP APC
・Other…
@duncanc
Or “Segment” plugin also works “SSL ( https:// )” ?
Requires the Common Plugin version 3 to be installed. You should install, or upgrade to, the latest version. See https://github.com/bramley/phplist-plugin-common
I installed the
・Common Plugin (3.0.3+20150828)
It worked without a problem.
Then next
・“Segment” plugin (2.1.0+20150903)
It does not work.
Same. become a “White Out” management console…
“Segment” plugin are using the “ob” function internally,
This function is not working?
So become a “White Out” management console?
@junysb3 At what point does the problem happen? Is it when you enable the plugin or when you compose a campaign?
@duncanc
It will occur when I upload the “Segment” plugin to plugins directory.
Even in a state that does not enable “Segment” plugin.
@junysb3 Possibly you are not copying all the files correctly.
Why can you not install through the Plugins page in phplist?
@duncanc Many thanks.
I installed the
Then next
I install through the Plugins page in phplist.
It worked without a problem…
