hello, i am using phplist, version 3.0.5, installed on my own server. ( for the record a very old version of Phplist but i upgraded recently and everythign seemed ok , i have never had a problem logging in
I was having issues about the wrong pageroot, ( i use /mail2/ rather than the standard /lists/) I knew that the correct page root was in the config extended file, but I found a post here that explained that you only use config.php , not config_extended.php (where the correct pageroot was noted). so i did as suggested and renamed the 2 files, thinking that would fix my issue
i logged out of everything, ( actually i did a restart on my pc) and went to connect the the phplist admin interface,
http://mydomain.com/mail2/admin/
but got a wrong password error;
I thought perhaps this was linked to my swapping the config file names, so i swapped them back around again, but still cannot log in;
Also when i add my email address to the Forgot password enter email address box i get this message
Failed sending a change password token
Any ideas on how to fix?
I tried on Firefox and on Chrome
Using Windows 10
