A Release Candidate for the upcoming phpList 3.3.1 is available for testing, including fixes for the following reported issues with phpList 3.3.0:
- Admin password requires reset after upgrade
- Links in campaign content do not redirect
- UUID missing for subscribers after upgrade
- Import subscribers does not generate UUID
If you have experienced issues with phpList 3.3.0 please install this update and see if those issues are resolved. This is your chance to find any remaining issues on your particular platform and setup, allowing them to be addressed before the final release. This is the first release candidate making the current version 3.3.1-RC1.
Download the Release Candidate here
Guidelines
- Upgrade from older releases following the usual upgrade process
- Use your phpList as normal, and report any new problems you find
Reporting issues
Report any issues you find to the phpList Bugtracker, selecting “3.3-RC4” as the Product Version
Use the usual bug fixing process if you know how to fix it
Happy testing!
