phpList 3.3.9 Release Candidate ready for testing
A Release Candidate for the upcoming phpList 3.3.9 is available for testing, including a link to a vcard which can be included using the [CONTACT] placeholder and can be imported by the subscriber, to add you to their address book and avoid local spam filtration.
Several other fixes and improvements are also included:
  • Faster loading of the Dashboard introduced on 3.3.8 -- check the issue on mantis -- https://mantis.phplist.org/view.php?id=19730 for more details
  • Fixed the problem with saving edits of templates with the same name
  • New ordering of campaigns with different default criteria for each tab
  • Several enhancements on labels related to open and click statistics
Full list of changes here
Download the Release Candidate here if you are running a version older than 3.3.7-RC1.
Guidelines
Upgrade from older releases following the usual upgrade process
Use your phpList as normal, and report any new problems you find
Reporting issues
Report any issues you find to the phpList Bugtracker, selecting “3.3.9-RC1” as the Product Version
Happy testing!
Hi everyone, considering the developments on this thread , a new Release Candidate for phpList 3.3.9 is now available to download.
Download for manual update here.
A new RC for 3.3.9 has been released so that everyone can test the recent changes made so that the [CONTACT] placeholder of the vCard is supported on text-format messages too.
More details here.
You can download the new RC for manual update here.
