A Release Candidate for upcoming phpList 3.5.0 is now available for testing.
This is a minor release with a few fixes and usability improvements.
Changes to look for
- Simplify the use of the phpmailer addCustomHeader() method, remove redundant methods and unused parameters in phplistmailer – thanks to @duncanc , see the pull request
- Include the seconds value on the Date header for it to be used on the bounces table – thanks to @duncanc, see the pull request
- Remove “–select one” from the select options of “Choose a template” in the format tab
- Add button styling on the " Add some more emails" option available after import on both import via .txt and import via CSV pages.
- Change the .cke width property to “Auto” instead of “100%” so that the drop-down options from the toolbar are not expanded in full width – originally reported by @alex01 here and addressed by @duncanc on changes to the CKEditor plugin.
- Updates to the front-end strings for the French Language – thanks to Alain Rihs
Download the Release Candidate here (see also ‘Upgrading’).
Guidelines
Upgrading
Upgrade from releases older than phpList 3.3.7-RC1 following the usual upgrade process
Activating the REST API
Reporting issues
This RC is available for testing until the final release expected on January 14th. If a new RC will be necessary based on the feedback shared, an announcement will be posted in advance.
Report any issues you find with phpList3 to the phpList Bugtracker, selecting “3.5.0-RC1” as the Product Version.
Happy testing!
