Should be an easy answer to get.
isn’t it inside the config.php ?
For an ie. i have the following setup in my config file:
define('MAILQUEUE_BATCH_SIZE', 0);
define('MAILQUEUE_BATCH_PERIOD', 1800);
Best regards,
Ruslán
