@smokinjo Working from the bottom up, the first page (jpac.ca) genuinely doesn’t exist. The eco2 page does exist but phplist is getting a 0 return code, which doesn’t make much sense. The time between the first line for eco2 and the last line is 10s which suggests some sort of problem in connecting and then timing out.
Does this work with any other web page? If not then i suggest you raise the problem with your hosting company.
@smokinjo That page is being served using HTTP/2.0 which might not be supported by your php release. On my local phplist using php 5.6 I was able to retrieve that page.
@smokinjo The page is now being served using HTTP/1.1 so either I misunderstood what was happening or something has changed. But on my server the page is retrieved by phplist. That is with php 7 and phplist 3.6.
It might be a problem with the server, the version of php, but I don’t really have any suggestion apart from upgrading php. You should also upgrade phplist to the latest version but I don’t think that is causing the problem.
@duncanc
I have not touched the server in any way, so I am not sure why you saw a change from http 1.1 and 2.0
I saw phpist 3.2.7, did you mean this?
I will try just installing the latest version of phplist and see what happens. It is an easy test, and not changes to the server are needed. I iwll let you know the results.
