Release Candidate for the 3.6.11 version is available for testing.
You can get a copy of the RC version from GitHub or SourceForge.
Changes included in this release:
- Avoid PHP warnings when
open_basediris enabled. See Pull Request #905. - Load the subscribers’ list numbers asynchronously to avoid delay in page loading for accounts with large amounts of subscribers. See Pull Request #909.
- Avoid division by zero everywhere. See Pull Request #913.
- Load powered image on SSL across all browsers. See Pull Request #917.
- Set Docker to use the powered images on SSL. See Pull Request #918.
- Avoid PHP 8.2 warning about dynamic properties. See Pull Request #920.
- Update PEAR HTTP_Request2 package to version 2.5.1. See Pull Request #921.
- Disable Automatic Updater to avoid errors when upgrading to the latest version. A fix for the Updater is expected soon. See Pull Request #913.
Activating the REST API
If you haven’t checked the REST API yet, you can see the dedicated chapter in the manual to help you get started with it: API and Integrations 4.
Reporting issues
Report any issues you find with phpList3 RC to the phpList3 GitHub repository, selecting “release candidate” in the Labels’ dropdown menu.
Happy testing!
