Hi guys,
I have a question for install Segment plugin for version 3.3.1 phplist. I read through the installation requirement doc, but didn’t see anything related to if newest version phplist will works for this plugin.
Here is the description:
"### Dependencies ###
Requires php version 5.4.0 or later. Please check your php version before installing the plugin, otherwise phplist will fail (probably a white page).
This plugin requires the Common Plugin version 3.5.6 or greater to also be installed, and will not work without that. You must install that plugin or upgrade to the latest version if it is already installed.
See https://github.com/bramley/phplist-plugin-common "
Any ideas or suggestions? Please let me know. Thanks.
Thank you for you replied Dragorider.
I tried to install manually, but it give me a white page after I pasted both “SegmentPlugin.php” and “directory SegmentPlugin” into the plugins folder. What I did wrong?
There is a message on my Manage Plugins page said “The plugin root directory is not writable, please install plugins manually”. so that’s why I’m doing manually.
@Benc With only Common Plugin installed (i.e. without the Segment plugin), does phplist work normally?
One possible problem is the php timezone setting. Ensure that you have that set, or install the Timezone plugin and then set the timezone on the Settings page.
Hi, @duncanc,
Sorry for late reply, I installed the time zone plugin and set the timezone on setting page as an empty value. But when I plugin the SegmentPlugin, still give me a white page. Do you have any other ideas why is this happened?
In the Timezone group on the Settings page you can specify the php timezone.
This should be a value similar to ‘Australia/Sydney’. See http://php.net/manual/en/timezones.php for the supported timezones.
