@piotramp You can use the mailgun smtp server with phplist.
There is also a plugin for Mailgun that uses their API, which might give a higher throughput. On the Manage Plugins page follow the “find more plugins” link.
In either case ensure that you set the phplist batch and throttle so that it remains within your limit with Mailgun.
