Want to upgrade from 2.10.2 to 3.0.12. I read the instructions
(•Backup your database
•Copy your config.php file in a safe place
•Download the latest version of phpList
•Overwrite all of the code of the current version with the new one. You can upload the “lists” directory and all it contains
•Copy your config.php back
•Login to the phpList admin pages and click the “upgrade” link
•Just to be sure, use the “Verify database structure” page to check that your database structure is correct)
But I already fail with the first Point. Where to find the files I Need to copy and save? Just in case it will not work with the upgrade - how to return to the old Version?
I downloaded the file, searched and found an unzip (peazip) programme, unzipped it, found 2027 files but no install and no exe file. Searched for, found and read the upgrade instructions and struggled completely. And help for dummies available?
(remark: in a similar event I lost already a complete data base, so I’m scared to crash and lose everything again)
Thanks in advance, Bernd
