Hello all, I upgraded to 3.3.1 and used the old config file. Everything works, however, the “exclude lists” feature no longer works in campaigns. The feature is there, you can click on it, but it only lists the category of the lists. When you click on the category, it does nothing. Is there a new version of the config file that should be used with additional code?
BTW, the improvements appear to be much better when working with the databases.
