@mbrampton The file lists/updater/index.php needs to be amended. It has changed since the Mantis issue was raised so the actuall change is a bit different
Thanks very much. That solved the problem. In case anyone else looks at this, the line number varies through different releases. I found the statement at line 318, and after the upgrade it is 324. But it’s easy to find by searching for $dsn.
