I tried to use the updater, it starts but this error message is returned at the initialisation step. How can I fill the download folder so that the updater will run? And with what?
A question about the logic of this process. I understand the steps, as they stand they are fine, but the checking of the download folder should occur on the download step. I would think… Or is there some check at initialise that requires some (particular) files in the download folder?
I would be grateful for your help.
