I have installed phpList on my Almalinux9 VPS running an Nginx webserver. I believe I installed phpList correctly. The ‘/lists’ directory is currently located inside ‘/usr/share/nginx/html’, which is where I have the rest of my website files.
After some trial and error, I suspect all of my configuration files are done correctly.
I am trying to setup phpList at the domain ‘php(dot)mydomain(dot)net’ – when I visit this domain, I get an error stating: “Database error 1146 while doing query Table ‘mydatabase.phplist_subscribepage’ doesn’t exist”.
When I visit ‘php(dot)mydomain(dot)net/lists/admin’, I get a 404 Not Found error.
When I visit ‘php(dot)mydomain(dot)net/admin/index.php?page=install’ (a suggestion from the robot), I am greeted with the phpList page with the following error at the top: “The pageroot in your config “/lists” does not match the current location “”. Check your config file.” – Then, if I attempt to click on ‘initialize database’, again I am met with a 404 Not Found error.
I am at the end of my rope here. I have no idea what else to try. I tried changing the $pageroot in config_extended.php to several different things (including an empty string), but nothing worked. I have tried a fresh install of phpList, but got the same results.
Does anyone have any other ideas??
