I still run an older phplist version because the plugin interface changed at some point and I couldn’t keep up. Also, everything still works more than OK, so no pressure. Or so I thought.
PS. I also only send two bulk emails per year so I’m starting to notice below issue just now.
For the longest time this has worked well btw. After 4 consecutive bounces (set in config.php) the subscriber gets blacklisted. I only send twice a year so it can take two years before a subscriber is actually blacklisted, but ok.
I am currently sending out an email and quite accidentally I noticed a subscriber who SHOULD have been blacklisted, but he’s not ? The interface clearly shows bounces were received and processed for this subscriber, with proper date stamp and everything.
So the cron job that checks the emails and updates the bounce list in the database works.
/usr/local/bin/php -q /home/xxx/public_html/xxx/admin/index.php -c /home/xxx/public_html/xxx/config/config.php -pprocessbounces
What however could cause phplist not to blacklist these subscribers ?
Last year somewhere php was updated, other than that nothing has changed for many years.
Where do I look to try and fix it. I understand completely when you say ‘update phplist’ but please understand I need to try and remedy this first under current conditions. The email needs to be sent ‘now’ before I spend weeks trying to update phplist (yes, I’m that uncomfortable with it + the plugins, it worries me)
Does the issue of not blacklisting sound familiar ? Perhaps it is an issue that has been encountered before ? Or what process could be failing exactly ? Where do I look for errors (if there are any - I certainly am not seeing any errors)
I now also realize I used to get emails when the cron job blacklisted subscribers and I have not seen such emails in a while.
