idk what to do, but my status :submitted. and letters do not starting to sending. what is happening, what i should do?
Sounds like you haven’t set the embargo time to before the default set in your sending settings.
ty, but i didn’t change anything. i just reboot container on ubuntu, then my campaign just did not starting. idk what i should do in this situation. time is good, campaign should start. so i tried to send 1 e-mail for test , and that was delivered. but that was test e-mail in the settings of campaign
Hi, I’ve come across the same issue.
@paul123 did you find a solution to this case? ![]()
