exegate
#1
I’ve just installed 3.2.3 on xampp (running PHP 5.6.14)
and made the following changes in the config file:
define(“PHPMAILERHOST”,‘smtp.domain.com’);
$phpmailer_smtpuser = ‘your_mail_username’;
$phpmailer_smtppassword = ‘your_mail_password’;
define(‘PHPMAILERPORT’,465);
define(“PHPMAILER_SECURE”,‘tls’);
However, the test mail i tried sending failed.
What other changes must I make?
duncanc
#2
See this topic for how to enable smtp debug Upgrade 3.2.3 and SMTP
exegate
#3
With “SMTPDebug = 4”, I resent the test message. What does the following error message mean?
2015-12-05 13:38:54 Connection: opening to smtp.myserver.com:465, timeout=5, options=array ( ) 2015-12-05 13:38:54 Connection: opened 2015-12-05 13:38:59 SMTP -> get_lines(): $data is “” 2015-12-05 13:38:59 SMTP -> get_lines(): $str is “” 2015-12-05 13:38:59 SMTP -> get_lines(): timed-out (5 sec) 2015-12-05 13:38:59 SERVER -> CLIENT: 2015-12-05 13:38:59 CLIENT -> SERVER: EHLO localhost 2015-12-05 13:38:59 SMTP -> get_lines(): $data is “” 2015-12-05 13:38:59 SMTP -> get_lines(): $str is “” 2015-12-05 13:38:59 SERVER -> CLIENT: 2015-12-05 13:38:59 SMTP ERROR: EHLO command failed: 2015-12-05 13:38:59 SMTP NOTICE: EOF caught while checking if connected 2015-12-05 13:38:59 Connection: closed 2015-12-05 13:38:59 SMTP Error: Could not connect to SMTP host. 2015-12-05 13:38:59 SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
duncanc
#4
I guess that the port you are trying to use is being blocked. Can you try using an unencrypted connection?
exegate
#6
Success. You made my day duncanc. Thank you.
