yes test email is existing subscriber. I think problem is with smtp connection.
<?php
** The minimum requirements to get phpList working are in this file.*
** If you are interested in tweaking more options, check out the config_extended.php file*
** or visit system:config [phpList Resources]*
** ** NOTE: To use options from config_extended.php, you need to copy them to this file ***
// what is your Mysql database server hostname
$database_host = ‘localhost’;
// what is the name of the database we are using
$database_name = ‘pritdigi_phplistdb’;
// what user has access to this database
$database_user = ‘pritdigi_phplist’;
// and what is the password to login to control the database
$database_password = ‘prince@444’;
//# if your SMTP server is called “smtp.mydomain.com” you enter this below like this:
//# define(“PHPMAILERHOST”,‘smtp.mydomain.com’);
define(‘PHPMAILERHOST’, ‘localhost’);
define(‘PHPMAILERPORT’,2500);
define(‘PHPMAILER_SECURE’,false);
// this is here, to make sure you edited the config file and mails are not sent “accidentally”
// on unmanaged systems
define(‘TEST’, 0);
** Settings for handling bounces*
** This section is OPTIONAL, and not necessary to send out mailings, but it is highly recommended to correctly*
** set up bounce processing. Without processing of bounces your system will end up sending large amounts of*
** unnecessary messages, which overloads your own server, the receiving servers and internet traffic as a whole*
// Message envelope.
// This is the address that most bounces will be delivered to
// Your should make this an address that no PERSON reads
// but a mailbox that phpList can empty every so often, to process the bounces
// $message_envelope = ‘listbounces@yourdomain’;
// This can be ‘pop’ or ‘mbox’
$bounce_protocol = ‘pop’;
// commandline
$bounce_mailbox_host = ‘localhost’;
$bounce_mailbox_user = ‘popuser’;
$bounce_mailbox_password = ‘password’;
// the “port” is the remote port of the connection to retrieve the emails
// the default should be fine but if it doesn’t work, you can try the second
// second line
$bounce_mailbox_port = ‘110/pop3/notls’;
//$bounce_mailbox_port = “110/pop3”;
// it’s getting more common to have secure connections, in which case you probably want to use
//$bounce_mailbox_port = “995/pop3/ssl/novalidate-cert”;
// when the protocol is mbox specify this one
// it needs to be a local file in mbox format, accessible to your webserver user
$bounce_mailbox = ‘/var/mail/listbounces’;
// testing things.
$bounce_mailbox_purge = 1;
// how many bounces in a row need to have occurred for a user to be marked unconfirmed
// choose the hash method for password
// check the extended config for more info
// in most cases, it is fine to leave this as it is
define(‘HASH_ALGO’, ‘sha256’);
please help if there is any error in code.
