Since sommertime (I guess) the queue for newsletters (plugin autoresponders) seems not to work anymore.
Can really no one hep?
@dreamcreator Please be clearer on what is happening and what is not working as you expect.
I use Plugin Autoresponder for autonewsletters (follwup).
I guess since sometime it is not working any more only when I manually send the queue.
I use the task:
curl ‘http://list.istok.de/lists/admin/?page=processqueue&secret=bcc1…bef83ee’
@dreamcreator You need to give much more information about what is happening. Just saying that something is not working is not helpful.
At the very least capture the output of the curl command, and look at the Event Log page for anything that might be reported there. There will be entries in the event log each time processqueue is run.
The cron job on my server seems to work properly but I don’t see any entry on log.
Only this manually startet queue sending for example yesterday or now:
|23993|8 May 2022 13:50:15|It took 2 years 157 days 23 hours 50 minutes 03 seconds to send this message|
Cron job answer:
Task “curl ‘http://list.istok.de/lists/admin/?page=processqueue&secret=bcc1b…83ee’” successfully completed in 1 seconds. See details
404 Not Found
Not Found
The requested document was not found on this server.
Web Server at istok.de <!-- - Unfortunately, Microsoft has added a clever new - "feature" to Internet Explorer. If the text of - an error's message is "too small", specifically - less than 512 bytes, Internet Explorer returns - its own error me...
Otherwise I get failures vie Email like:
Cron istok@ha01s021 (curl ‘http://list.istok.de/lists/admin/?page=processqueue&secret=bcc1b4…f83ee’) > /dev/null
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
100 1018 100 1018 0 0 28692 0 --:–:-- --:–:-- --:–:-- 29085
I also can’t view nothing (failure) under, with https, https or without :
list.istok.de/lists/admin/?page=processqueue&secret=bcc1b…bef83ee
which has ever worked
@dreamcreator At the very least the URL in the curl command is not correct. Compare that with the URL you use to login to phplist.
Thank You, it seems to work.
I don’t know how it was working till shortly with /lists/
