Bounces are going to my mailbox but stats show no bounces. I’m not really clear about what process bounces does. Does it register the bounce in the db and delete them from my mailbox, or does it just mark those addresses as unconfirmed and count how many times they have bounced? What should my settings be? Here is what I have.
$message_envelope = ‘php-bounce@myexample.com’;
$bounce_protocol = ‘pop’;
I don’t think I am using pop so I left the next three lines as is
$bounce_mailbox_host = ‘localhost’;
$bounce_mailbox_user = ‘popuser’;
$bounce_mailbox_password = ‘password’;
$bounce_mailbox_port = ‘110/pop3/notls’;
$bounce_mailbox = ‘/var/spool/mail/listbounces’;
$bounce_mailbox_purge = 1;
$bounce_unsubscribe_threshold = 2;
