Hi
phpList ltd. - v3.3.1
It’s possible setting the Reply-to in the campaign settings or config file
It is important to split the bounces from the answers
thanks advance
Hi
thanks advance
It sounds like you might not have configured bounce handling if bounces are going to the From address. See the explanation in config_extended.php and copy that section to your config.php file.
Sorry, I seen now this post
I would like set a reply to:
It is possible in config
thank advance
