I installed the latest version of phplist on my domain and using my SMTP works well.
Now I would like to configure to send the newsletter an exchange SMTP of OVH.
I set this:
define(‘PHPMAILERHOST’, ‘ex.mail.ovh.net’);
$phpmailer_smtpuser = ‘myuser’;
$phpmailer_smtppassword = ‘mypassword’;
$phpmailer_smtpport = ‘587’;
$phpmailer_smtpsecure = ‘tls’;
With the same data with phpmailer and a test script sending works.
I can not understand what is wrong setting of phplist.
thank you
federico
@federico337 You can enable smtp debugging in your config.php file. Look in config_extended.php for the line to use, then copy to config.php.
If you then send a test message there will be some debug output that might show what is wrong.
from the OVH guide:
“Server: SMTP”:
Server Host: ex.mail.ovh.net.
Port: 587.
Encryption: STARTTLS.
Authentication: normal password.
User: your email address
the error is:
SMTP ERROR: DATA END command failed: 550 5.7.60 SMTP; Client does not have permissions to send as this sender
SMTP Error: data not accepted.
CLIENT -> SERVER: QUIT
From your ealier posts I thought that these were the settings you were using when you got “Authentication unsuccessful”.
Do you have a valid (for OVH) email address for the $message_enveloper setting in your config file?
Try enabling debug in your test program to see what the difference in the output is.
I found the problem.
of the SMTP configuration information is correct.
the problem is OVH does not allow me to send with the email XXX@emai.com and autentification with email YYYY@email.com
Thanks for your help
regards
federico
