![SEGM|690x121]
upload://jP7cml4hDZ5u5NTav8TpSW8grD7.png)Hi
Unfortunately I can’t activate the plugin
phpList 3.3.9
PHP 5.5.38
I’ve installed also the pluginlib.php and last version of Segment Plugin
I hope a help
Thanks advance
![SEGM|690x121]
phpList 3.3.9
PHP 5.5.38
I hope a help
Thanks advance
Have you installed the Common PLugin as the Segment plugin requires this to work. You may also need to upgrade your version of PHP, 5.5 is quite old now and basically unsupported and considered insecure by many hosts. Probably need to speak to your host about that.
@xanter the error message in your first screenshot states that version 3.9.0 of Common Plugin is required, you have version 3.5.8.
