Hi, I’ve just started using Phplist 3.5.5 (ubuntu 18.04)
Everything works beside the “save and continue” button in the send a campaign page. When I click the button, the page seems stuck and doesnt move to the next. While if I click on the 2-3-4 red button at the top or if I use the arrows, it works going to the next step (format -> scheduling -> lists, etc).
Is it normal? If not, any idea?
thanks
@barbara that button simply saves the current data and does not move on to another tab. “Continue” means to continue editing the campaign.
Thank you @duncanc
Good to know. I was used to a previous version with the button “next” and, as there’s also a “save draft” button, I tought the “save and continue” was like the old “next”.
Glad to know everything goes as it should,
Grazie!
