I’ve a problem with phpList.
I try to explain:
I have a phpList server that send campaigns to group of 10 mailboxes.
I had setup this server to send mail via crontab every 5 minutes and it send only 3 mails in a period (1 hour).
// Send a batch of 3 messages per batch period:
define(MAILQUEUE_BATCH_SIZE,3);
//batch period is set to 3600 seconds (=1 hour);
define(MAILQUEUE_BATCH_PERIOD,3600);
//autodelay in mailqueue
define(‘MAILQUEUE_AUTOTHROTTLE’,1);
Sometimes I have to reboot my server, if I reboot the server while phpList is sending, it stop sending and I can’t resume that campaign. In webGUI i can see that this campaign is in running.
There are any way to do that I can resume my sending campaign after a reboot?
@mgraps You can actually delete all rows from the phplist_sendprocess table if you are not currently processing the queue or processing bounces.
It is simpler to use a value for MAILQUEUE_THROTTLE, if you want to spread-out the sending. The way that autothrottle works is not really well defined.
@duncanc
Thanks for the reply.
I want to keep the parameter to avoid going to spam list.
My problem is that the mail sending process could take a long time and I would like to have a way to resume sending in case the flow stops due to a reboot.
