this line in list/admins/ui/php-ui-bootlist/functions.php
if ($page_title ==‘userclicks’) $page_title = s(‘Click Statistics’); /* REMOVE AFTER RESOLVE MANTIS #18945 */
stops the ver 3.3.3 from loading… when commented out things work.
Please explain
Please explain
@johntrot That code is incorrect, as it refers to an undefined variable.
https://mantis.phplist.org/view.php?id=18945#c60706
Because phplist generally ignores errors that was ignored. But some of my plugins enable error reporting which meant that this particular error was not ignored, causing the failure.
I think that I have fixed the error reporting so you should update plugins that are not the latest version. The Manage Plugins page now shows which plugins have updates.
@duncanc
Apparently this is now fixed…
I updated your plugin as suggested,
uncommented the first line in admin/ui/php_bootlist/functions.php and no problems.
However, I am having other problems with ver 3.3.3
I will discuss those issues in another topic
Thanks for this prompt fix.
