who can help me to check does below config are correct or not?
surely I have change sensitive information such as host/user/password.
# To use a SMTP server please give your server hostname here, leave it blank to use the standard
# PHP mail() command.
define('PHPMAILERHOST', 'mx.aise.com');
# in the above you can specify multiple SMTP servers like this:
# 'server1:port1;server2:port2;server3:port3' eg
#define('PHPMAILERHOST','smtp1.mydomain.com:25;smtp2.mydomain.com:2500;smtp3.phplist.com:5123');
# if you want to use smtp authentication when sending the email uncomment the following
# two lines and set the username and password to be the correct ones
$phpmailer_smtpuser = 'service';
#$phpmailer_smtppassword = 'abcdo';
## you can set this to send out via a different SMTP port
define('PHPMAILERPORT',25);
