A release candidate is available for testing for the upcoming version 3.6.2! This RC introduces several improvements and fixes.
Note: Given a large number of changes introduced in PHP 8, phpList cannot support yet these changes. This means that you might encounter issues with your phpList installation while using PHP 8 and it is advised to continue using versions prior to PHP 8. Also, have in mind that support for PHP 5 has been discontinued since 2019 and therefore you might encounter issues with your phpList installation. Currently, PHP 7 is a safe option for your phpList installation. You might want to have a look at the PHP release history.
Expected changes in this release:
New Features:
- PHP 8 fixes: Several minor changes have been made to make sure phpList complies with the latest PHP updates.
- Text templates: add text versions of templates as first-class citizens that can be fully managed within phpList. The default value for the text version of new templates and the value set for existing templates when the database is updated is set to
[CONTENT], so that phpListâs behavior remains unchanged unless the user edits the text template. See Pull Request. - More translations have been added in several languages.
Fixes:
- Improve layout on the âList Campaignsâ page after not displaying properly because of collision with a previous change. See Pull Request.
- Avoid PHP warning regarding null type. PHP 8 seems to be more strict about issuing warnings. These warnings are not issued using PHP 7 with error reporting enabled. See Pull Request.
- Fixed menu item for Update not to be displayed when not enabled. See Pull Request.
Improvements:
- Correct the validation of an empty string for an âemaillistâ config item. Correct the use of âreport_addressâ when it is empty (the same problem of using explode() on an empty string). See Mantis issue.
- Minor command-line subscriber export improvements. See Pull Request.
Guidelines
Upgrading
Upgrade from releases older than phpList 3.3.7-RC1 following the usual upgrade process. You can get a copy of the RC version on SourceForge as well.
Activating the REST API
If you havenât checked the REST API yet, you can see the dedicated chapter in the manual to help you get started with it: API and Integrations.
Reporting issues
Report any issues you find with phpList3 to the phpList Bugtracker, selecting â3.6.2-RC1â as the Product Version.
Happy testing!
Mariana
