Rejected hotmail phplist runs on a subdomain
I’ve read many similar posts.
phplist is installed on lists.mydomain.org.
Website address (without http://) lists.mydomain.org
Domain Name of your server (for email) mydomain.org
When I test emails sent from mydomain.org
SPF passed DKIM passed DMARC passed.
When email is sent from lists.mydomain.org fail, fail fail.
I haven’t been able to configure the DNS settings for lists.
I’d like to send emails through mydomain.org.
If I can get this corrected I feel my rejected hotmail, msn and outlook emails will decrease.
@StevenSchlossman SPF, DKIM and DMARC use the From address or the Return-Path addess (in phplist the $message_envelope setting in config.php). If you are using addresses on mydomain.org and not lists.mydomain.org then that should be ok.
You can use a site such as https://www.mail-tester.com/ to test these.
Config file has always been
$message_envelope = ‘bounces@mydomain.org’;
Campaign setting
Default for ‘From:’ in a campaign
communications@mydomain.org
Another useful site to check email is https://www.learndmarc.com/
Thank you
