Redirect problem
I have setup phplist and everything works OK, clicking on any link keeps me in the context except when I click on “start new campaign” , I am redirected to the http://mydomain.com/lists/admin/?page=send&id=26 instead of http://mydomain.com/dev/email/admin/?page=send
Any idea or any config that I need to update.
Thanks in advance.
@shahhetal Possibly you have the wrong value in your config file
# if you change the path to the phpList system, make the change here as well
$pageroot = '/lists';
You might also need to change the URLs for subscribe, unsubscribe etc. on the Settings page.
I did a fresh installation, and modified the $pageroot to $pageroot = ‘’; before initializing the database, but in the admin panel it keeps redirecting to /lists and I get page not found.
based on a previous post, I made it empty quotes instead of a “/”. [SOLVED] Pageroot problem after upgrading to 3.3.7
I haven’t seen any other posts addressing it.
This is located in the root directory. /var/www/html
Sites enabled config file document root = /var/www/html
