Hi, I am using PHP 3.3.1
I would like to configure sort of “timing” between each sending.
I mean: I have 10000 subscribers; I would like to sent not more than 1 message per second (for example).
I don’t need to configure this for specific list: it is enough for me configure this “delay” globally to this phplist installation.
Thank you very much!
Simply add the following to your config.php file (found in config_extended.php file)
# (or you can play with the autothrottle below)
define('MAILQUEUE_THROTTLE', 1);
