v3.6.13
campaign plugin:version2.4.3+20221231
common plugin: version3.26.0+20230425
MessageStatisticsPlugin: version2.4.1+20230714
segment plugin: version2.13.2+20230403
When using the segment plugin and filtering via regex I will see a list of potential emails that match the specific case such as regex id: [4]$ will be all users whose id ends in the number 4.
However, after using this method to select recipients, and after the process runs, there will be some emails that show opened and others as not opened as is usually the case.
However, if I go back and run the same query after a successful run I will see the same list of potential recipients and I can likewise queue them up. The question is does phplist NOT send these listed emails, for example, [4]$, again?
It is confusing because if they’ve already been sent, and the query runs again, I am under the impression that maybe they will be sent again which of course I don’t want to do.
Does phplist check right before sending that it shouldn’t, for example in this case, send them another email is the question?
