Hello. I run my own instance of phplist. Occasionally I receive mesages like the following:
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] Started
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] Sending in batches of 150 emails
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] Processing has started,
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] One campaign to process.
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] Please leave this window open. phpList will process your queue until all messages have been sent. This may take a while
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] Report of processing will be sent by email
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] Processing campaign 64
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] Looking for subscribers
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] Found them: 557 to process
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] Processed 557 out of 557 subscribers
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] It took 14 hours 46 mins 49 seconds to send this message
[Fri 26 Apr 2024 14:01] [xx.xx.xx.xx] Script stage: 4
To stop receiving these reports read: https://resources.phplist.com/system/config/send_queue_processing_report
It also says: When you have batch processing enabled, and run in small batches, and/or you run from commandline, you will want to switch this off, as you will receive loads of reports.
The link at the bottom goes to: system:config:send_queue_processing_report [phpList Resources]
which says:
Now, I assume it’s my instance of phplist that is sending this, however, I only sent 2 test emails.
So scratching my head - is someone else sending messages from phplist.com - it could be interpreted that way.
thanks
