I’ve searched for this issue for a couple of months now with no solution.
I have phplist v.3.6.7 installed on Ubuntu 18.04.2 LTS
Until about 3 months ago, it was working well. I was processing the queue from console manually (only send out once a month) using the command line phplist -pprocessqueue
Then I started getting this message on console:
# phplist -pprocessqueue
The following PHP extensions are missing:<br>mysqli<br>
There were acouple of other extensions on the list, but by re-installing them, the message for those went away. However, mysqli doesn’t, even after reinstalling it.
PHP info shows:
mysqli
MysqlI Support | enabled |
Client API library version | mysqlnd 7.4.28 |
Active Persistent Links | 0 |
Inactive Persistent Links | 0 |
Active Links | 0 |
Directive | Local Value | Master Value |
mysqli.allow_local_infile | On | On |
mysqli.allow_persistent | On | On |
mysqli.default_host | no value | no value |
mysqli.default_port | 3306 | 3306 |
mysqli.default_pw | no value | no value |
mysqli.default_socket | no value | no value |
mysqli.default_user | no value | no value |
mysqli.max_links | Unlimited | Unlimited |
mysqli.max_persistent | Unlimited | Unlimited |
mysqli.reconnect | Off | Off |
mysqli.rollback_on_cached_plink | Off | Off |
Processing the queue from the browser works fine.
PHP v.7.4.28
phplist v.3.6.7
I am at a loss as to why processing the list from console, doesn’t seem to recognize mysqli. I’ve also updated phplist after the issue started, but the error persists.
Any suggestions are welcome.
Thank you,
Tomás
