I have updated PHPList to the latest version v3.3.1 and I am currently having a problem processing bounces via cron. It is giving me an error message saying:
“Error: processbounces does not process commandline”
How can I fix this?
How can I fix this?
@renantea Please show the command used by the cron job.
hi… i have been using the same command like this:
./phplist -pprocessbounces
@renantea Presumably phplist is a shell script, so you need to show its contents.
ahh… here’s the shell script:
#!/bin/bash
/usr/local/php5/bin/php /Websites/myserver/lists/admin/index.php -c /Websites/myserver/config/config.php $*
@renantea Do you have a cron job to process the queue? If so, how is that different?
You could try leaving a space after the first p
./phplist -p processbounces
Thanks @duncanc ! I never realised that. Problem solved!
