Hello everyone, first post here, so first of all, hi!
I recently finished migrating a phplist 3.6.10 from centos8 to ubuntu 22.04 and everything is working fine… except for bounces. The server is running:
Exim 4.95 listening to localhost only
Apache server 2.4.54 with PHP-FMP 8.2.1
MariaDB 15.1
The bounces are configured to check an mbox file (/var/mail/mails)
The file has read access to everyone and doing:
sudo -u www-data cat /var/mail/mails
the file opens properly, but if I run this command (that I have set up in a cron job) I get an error:
/usr/local/bin/phplist -pprocessbounces
phpList - phpList version 3.6.10 (c) 2000-2023 phpList Ltd, https://www.phplist.com
phpList - Cannot open mailbox file Can’t open mailbox /var/mail/mails: no such mailbox
phpList - Download failed, exiting
Here’s the piece of config.php regarding the bounces configuration. I removed the comments and the bounce e-mail address just for clarity and safety:
define(‘PHPMAILERHOST’, ‘localhost’);
define(‘PHPMAILER_SECURE’,‘false’);
define(‘TEST’, 0);
$message_envelope = ‘REDACTED’;
$bounce_protocol = ‘mbox’;
$bounce_mailbox = ‘/var/mail/mails’;
$bounce_mailbox_purge = 1;
$bounce_unsubscribe_threshold = 50;
What I tried so far:
I made a symlink to the mail file at the lists folder and then pointed config.php there. Same result.
Changed the owner of the mails file (although the permissions are -rw-rw-rw- which means everyone can read and write it) with no luck either.
Changed define(‘MANUALLY_PROCESS_BOUNCES’, 1); to 0 just in case that could somehow be the problem. Again no luck.
I downloaded the mails file and opened it with an mbox viewer (just to be sure that the file format is correct). The file opened with no issues.
I ran out of ideas. Any help here would be very appreciated.
Thanks!
