How can i add to the already predefined templates in the CKEditor plugin?
I want to make some more pre-defined templates and add it to the list of pre-defined templates.
where should i edit the code to add these templates.
Should i edit it directly in the CKEditor Plugin folder or somewhere else?
Plz help.
All the help is really appreciated.
I am using phpList version 3.2.1.
Thanks in advance.
duncanc
November 20, 2015, 6:20am
#2
@carldcosta26 What are you referring to by “templates”? CKEditor does not have anything called templates.
i found the file
Its in this folder
lists\admin\plugins\CKEditorPlugin\ckeditor\plugins\templates\templates\default.js
duncanc
November 20, 2015, 7:23am
#4
That is a plugin for CKEditor.The name “template” is unrelated to a phplist template so this might not do what you want.
Instead of modifying the file you identified, a better approach is to create a custom configuration file and put the code there. That way it will not be overwritten when you upgrade the phplist plugin. see https://github.com/bramley/phplist-plugin-ckeditor#custom-configuration
The phplist Content Areas plugin https://resources.phplist.com/plugin/contentareas might provide you with a better solution if you want to have several pre-defined layouts.
Thank you very much for this information
I will have a look at it.
