Hi @Disaster.net the latest line of “my” config.php file is 84 (it’s related to the hash method for password) then it seems you 've added some unknown settings here, isn’t ?
Which version 're you using?
Sorry for my late…
my version of PHPList is 3.5.0.
and my config … is different…
/ Message envelope. This is the email that system messages come from
// it is useful to make this one where you can process the bounces on
// you will probably get a X-Authentication-Warning in your message
// when using this with sendmail
// NOTE: this is very different from the From: line in a message
// to use this feature, uncomment the following line, and change the email address
// to some existing account on your system
// requires PHP version > “4.0.5” and “4.3.1+” without safe_mode
// $message_envelope = ‘listbounces@yourdomain’;
// This can be ‘pop’ or ‘mbox’
$bounce_protocol = ‘pop’;
// commandline
$bounce_mailbox_host = ‘MY_HOST’;
$bounce_mailbox_user = ‘MY_EMAIL’;
$bounce_mailbox_password = 'MY_PWD’;
// the “port” is the remote port of the connection to retrieve the emails
// the default should be fine but if it doesn’t work, you can try the second
// second line
$bounce_mailbox_port = ‘2525/pop3’;
//$bounce_mailbox_port = “110/pop3”;
// it’s getting more common to have secure connections, in which case you probably want to use
//$bounce_mailbox_port = “465/pop3/ssl/novalidate-cert”;
