I have phplist v3.6.12 installed.
It was working fine until nov 8th. On nov 9th after a campaign was submitted (Active campaigns) it never starts sending the emails.
What could be happening? Where else can I see what is happening?
Nothing appears in the Event Log page
Please your help would be appreciated
Hey Mauricio,
we have the same problem. We were start sending a campaign at nov 8th wich worked fine according to the processing report E-Mail but since nov 9th we dont get any report anymore and the process of the campaign list stopped. We are even not able to send test Mails since that date.
After enabling verbose adding “define(‘VERBOSE’, 1);” in the config.php file
In order not to wait for the cron, I tried to trigger the camapings manualy issuing on the linux command line:
su phplistuser -c “/usr/local/bin/phplist2 -pprocessqueue > /dev/null”
Then I clicked on System → Log of Events and nothing new since nov 8th.
The last message on nov 8th is:
Found them: 13621 to process
So I tried the same command wihout redirecting to /dev/null
su phplistuser -c “/usr/local/bin/phplist2 -pprocessqueue”
An got the following:
phpList - phpList version 3.6.12 (c) 2000-2023 phpList Ltd, https://www.phplist.com
phpList - A process for this page is already running and it was still alive 0 seconds ago
phpList - Running commandline, quitting. We’ll find out what to do in the next run.
Then I tried the same command on other working phplist
su phplistuser -c “/usr/local/bin/phplist3 -pprocessqueue”
This time, I got the following:
phpList - phpList version 3.6.14 (c) 2000-2023 phpList Ltd, https://www.phplist.com
phpList - Started [0.3511760000] (285)
phpList - Script stage: 6 [0.0018280000] (291)
phpList - Finished, Nothing to do [0.0006760000] (294)
phpList - Finished, All done [0.0798980000] (301)
For me, it seems that some process is stuck in my phplist2
@msrodrigp phplist inserts a row into the sendprocess table at the start of queue processing, then deletes that at the end. This is to stop another run of processqueue concurrently. The second run will see the row in the table and exit.
If a row was left in the table then phplist must have terminated abnormally. The row should eventually get deleted by a further run of processqueue after 10 minutes.
