Hi! I’m using the free phpList.com remote queue processing for some time now and suddenly it isn’t working anymore on multiple installations. It keeps saying “submitted”. Something wrong?
Also in the documentation is says "If you wish to disable this functionality in the future, go back to ?page=processqueue and click the Reset Choice button. " but there’s no such option!
For that to appear you need to add this line to your config file
define('SHOW_PQCHOICE',true);
Thanks duncanc, that shows the option.
But doesn’t anyone know if there is a problem with the free remote queue hosting service?
If i login to my account there is also nothing in the “status” page, but i have a message pending.
@ovans It is probably quickest to raise an issue using the Contact Us form when you are logged-in to your phplist.com account.
