After clicking subscribe I get this error: " Sorry, sending the message to request your confirmation failed."
Is there a workaround? — Based on an earlier post I added define(‘PHPMAILERSUBSCRIBEHOST’,’’); at the bottom of the config.php but that does not resolve it.
config.php:
//# if your SMTP server is called “smtp.mydomain.com” you enter this below like this:
//# define(“PHPMAILERHOST”,‘smtp.mydomain.com’);
//added # to 3 rows below #define(‘PHPMAILERHOST’, ‘localhost’); #define(‘PHPMAILERPORT’,2500); #define(‘PHPMAILER_SECURE’,false);
config_extended.php:
// To use a SMTP server please give your server hostname here, leave it blank to use the standard
// PHP mail() command.
define(‘PHPMAILERHOST’, ‘’);
