Hi everyone and happy New Year!
A Release Candidate for the upcoming phpList 3.6.0 is now available for testing. This is a minor release but includes security enhancements.
Changes to look for
Functionality Enhancement
- Hook has been added for plugins to allow them to determine if an email address should be blacklisted or not. See Pull Request.
Guidelines
Upgrading
Upgrade from releases older than phpList 3.3.7-RC1 following the usual upgrade process. You can get a copy of the RC version on SourceForge as well.
Activating the REST API
If you haven’t checked the REST API yet, you can see the dedicated chapter in the manual to help you get started with it: API and Integrations .
Reporting issues
Report any issues you find with phpList3 to the phpList Bugtracker, selecting “3.6.0-RC1” as the Product Version.
Happy testing!
Mariana
