phpList 3.5.7 Release candidate is ready for testing
Hi everyone,
A Release Candidate for the upcoming phpList 3.5.7 is now available for testing. This release introduces security enforcements on the authentication process.
Fixes to look for:
  • Dashboard page title has been renamed from “Upgrade phpList” to “Update database” to avoid confusion. Thanks to @hktang for the Pull Request.
  • Session fixation: The application now generates a new session key upon authentication to avoid unauthenticated users to obtain key on a legitimate user.
  • Sanitise the browser trail cookie to prevent cross-site scripting.
Guidelines
Upgrading
Upgrade from releases older than phpList 3.3.7-RC1 following the usual upgrade process
Activating the REST API
Reporting issues
Report any issues you find with phpList3 to the phpList Bugtracker, selecting “3.5.7-RC1” as the Product Version.
Happy testing!
