phpList 3.5.5 Release Candidate ready for testing
Hi everyone,
A release candidate for phpList 3.5.5 is now available for testing.
This release includes additional security enhancements to avoid abuse from an authenticated user.
Changes have been made to address the following issues:
  1. Cross Site Scripting Vulnerability on ā€œSend a campaignā€ page: The ā€œSend a web pageā€ URL value has now been encoded and the emails set to receive the notifications are verified. You can check the following GitHub issues for details – 1, 2
  2. Cross Site Scripting Vulnerability on ā€œManage administratorsā€ – the email address of an admin has now been sanitized
  3. Cross Site Scripting Vulnerability on ā€œBounce rulesā€ – unnecessary JS action has now been removed
  4. Cross Site Scripting Vulnerability on ā€œName of the organisationā€ option of ā€œSettingsā€ page – the use of tags has now been restricted and JS disallowed
  5. Cross Site Scripting Vulnerability on ā€œImport subscribersā€ via SVG upload – tags in CSV import headers have now been ignored
Thanks to @Songohan22 for reporting the issues.
Other changes to look for
  • Avoided warnings about $pageroot when phplist is installed in the web root, and improved warning message to include values that don’t match – thanks to @duncanc, see the pull request
  • Removed redundant code following changes included in phpList 3.5.4 – thanks to @duncanc, see the pull request
  • added SameSite to the browsetrail cookie to handle warnings in Firefox – The SameSite attribute of the Set-Cookie HTTP response header allows you to declare if your cookie should be restricted to a first-party or same-site context – more information in the mantis issue, thanks to @duncanc for raising this
Download the Release Candidate here (see also ā€˜Upgrading’).
Guidelines
Upgrading
Upgrade from releases older than phpList 3.3.7-RC1 following the usual upgrade process
Activating the REST API
Reporting issues
Report any issues you find with phpList3 to the phpList Bugtracker, selecting ā€œ3.5.5-RC1ā€ as the Product Version.
Happy testing!
