Hello everyone, hope all of you are safe and healthy!
A release Candidate for upcoming phpList 3.5.4 is now available for testing.
This release includes several fixes and usability improvements.
Changes to look for
Usability Improvements
- Clickable link at the top of the click stats page – thanks to @samtuke, see the pull request
- Added HTTP_Request2 as a fallback when curl is not available – thanks to @duncanc, see the pull request for more details.
- Updater menu entry is now shown only for superusers
- The updater handles deletion of broken symlinks
- Help added for the website field on the Settings page and updated help texts about date format and ’ tracking codes – thanks to @duncanc
Fixes:
- Updated default list of TLDs – thanks to @duncanc for pointing it out the problem
- Fixed incorrect statistics link in German installations, due to incorrect translation see mantis issue – please consider that fetching translations won’t fix the issue for now. It’s the update itself that uses the corrected version. Thanks to @jimbocity for reporting it.
- Fixed broken link in the Install file – thanks to Hiroyuki Sato
Other
- Changed config value for "$database_host " from ‘localhost’ to ‘dbhost’ – enabling a default setup that works with a DB that is not on the same machine
Download the Release Candidate here (see also ‘Upgrading’).
Guidelines
Upgrading
Upgrade from releases older than phpList 3.3.7-RC1 following the usual upgrade process
Activating the REST API
Reporting issues
Report any issues you find with phpList3 to the phpList Bugtracker, selecting “3.5.4-RC1” as the Product Version.
Happy testing!
