phpList 3.5.3 is now available for download, including Matomo Analytics Integration, PHPMailer update and 5 other changes.
Matomo Integration is now available as an alternative to Google Analytics. You can choose between Matomo or Google Analytics in the Settings page of your account.
Similarly to the current GA parameters, when selected, each URL will have four additional query parameters that will be displayed and can be edited on the Finish tab when composing a campaign. The data is not collected, stored or viewed in phpList.
Special thanks to our community member Duncan Cameron for implementing this feature.
You can see more details about the changes on the pull request.
Other changes to look for
- A configuration setting can now be used to allow customising the format of a displayed DATE – see the pull request. Check how it is used via the “Help” option.
- [Security Fix]: Implement an XSS filter in /lists/admin/template.php file to avoid privilege elevation – thanks to Dien Pham for reporting the issue and testing the fix.
- PHPMailer upgraded to version 6.1.5 from PHPMailer 6.1.1 – thanks to @duncanc, see the pull request
- Removed unnecessary function calls for page category and subcategory, avoiding repeated calls of some functions and reducing loading time for the homepage – thanks to @duncanc , see the pull request
Check the release notes for the full list of changes and references to the pull requests.
Please make sure to report any issues you find with phpList3 to the phpList Bugtracker, selecting “3.5.3” as the Product Version.
Support
Need help upgrading your phpList server to the most recent version? Ask the community at discuss.phplist.com. Professional support from community experts, as well as manuals, source code, and developer resources, can be found at phplist.org. Report bugs to the bugtracker!
Want to focus on campaigns and forget hosting headaches? Sign up at phplist.com for an account with everything included. Send from 300 free messages to 30 million messages per month.
Community-made
This release is the work of @duncanc, Dien Pham, Steven Adger and other Open Source community members who have submitted bug reports and valuable feedback, as well as phpList Ltd developers. To get involved in phpList development, check out the developer resources pages.
You can share the update on your social media channels using the links below:
Twitter:
Facebook:
LinkedIn:
Mastodon:
Telegram:
